if you have encountered the issue, that hard disk not found when installing operating system on a new hard drive or on a existing hard drive for the latest generation laptops. then we have to load New Intel RST 18.30.0.1135 WHQL One driver , download and copy paste it on the USB bootable thump drive / pen drive and then when installing click browse for drivers and choose the folder that you downloaded and copied to the pendrive and install the Intel RST driver, now your hard disk or SSD or m.2 will show in the list of hard disk, now you can install your operating systems.
Download:
check below
The SetupRST.exe is the new installer that will install the Intel RST driver and start the process of installing the Intel® Optane™ Memory and Storage Management application from the Microsoft Store*
Purpose
The Intel® Rapid Storage Technology (Intel® RST) Driver 18.6.1.1016 supports the configuration and enabling of multiple features including:
Notes
Download:
check below
Detailed Description
Note: Intel recommends that end users utilize driver updates provided by their system manufacturer/provider or via Windows* Update to eliminate the potential impact caused by loading non-customized drivers. System manufacturers regularly customize Intel generic drivers to meet the needs of their specific system design. In such cases, use of the Intel generic driver update is not recommended.The SetupRST.exe is the new installer that will install the Intel RST driver and start the process of installing the Intel® Optane™ Memory and Storage Management application from the Microsoft Store*
Purpose
- System acceleration with Intel® Optane™ memory
- Configuration and maintenance of RAID 0/1/5/10
- Intel® VMD support on 11th Gen platforms (See more details here)
Notes
- Support for Microsoft Windows* 11 x64 OS
- The Intel® Rapid Storage Technology (Intel® RST) Driver 18.6.1.1016 supports 10th Gen and 11th Gen Intel Core platforms.
- See the Release Notes or Readme files for installation instructions, supported hardware, what is new, bug fixes, and known issues.
- Additional assistance can be found here:
- RAID related support: Intel® Rapid Storage Technology Support page
- Intel® Optane™ Memory User and Installation Guide
- Intel® Optane™ memory-related support:Intel® Optane™ Memory support
