Asus case ASUS K50C SATA not detecting after BIOS update
Asus branded model case studies, explain the case with photos or in a clear manner. so the other will be able to understand it. help each other.
syed
Asus
ASUS K50C
ASUS K50C
Issue: the Asus Model K50C motherboard's BIOS reprogrammed with version v.207 & v.209. After flashing the BIOS reloaded with manufacturer default values, after that the SATA hard disk and SATA devices are not detected.
The Fix: download and run the
To view the content, you need to Sign In .
utility, and unzip it and copy to a bootable pen drive and make boot from that pen drive, after booting from pen drive the command prompt window will appear there type the below line
Distorted sound in Windows 7 on some Asus K50C models
The problem is solved by updating the BIOS to version v.207 or to newer one.
That's it.
