Dell case Dell E6540 RAM not properly detected.battery LED blinks WiFi and HDD LED solid
Dell branded model case studies, explain the case with photos or in a clear manner. so the other will be able to understand it. help each other.
Sana
Moderator
Dell
Dell Latitude E6540 VALA0 la-9411p
Dell Latitude E6540
The Dell E6540
Issue: RAM not detected well, when we power up the laptop the battery LED blinks WiFi and HDD LED glows solid. This symptoms are generally RAM issues it is mentioned in the Dell website dell.com
Sollution: just make sure the CPU is properly installed , reseat the CPU solved the issue.
Schematic no : Dell Latitude E6540 VALA0 la-9411p
