Below is the full and brief explanation of the signals and technologies STV, OE, CKV, VGL, VGH, and COF, which are commonly used in LED/LCD TV T-Con boards and panels
Instructs the panel to start driving from the vertical direction in the scanning process.
It provides a trigger pulse, which starts the scan in the gate driver circuit.
Provides a clock signal to the gate driver.
There is a CKV pulse for each gate line, which activates the pixels on the panel.
Used to enable/disable the output of the gate driver.
Usually helps in controlling the on/off of the pixel drive.
A high voltage supply (usually +20V or more) used in the gate driver circuit.
It is used to create the ON condition of the gate line.
Low voltage supply of the gate drive (usually -6V to -10V).
It is used to create the OFF condition of the gate line.
This is a technology where the IC is directly connected to a flexible film.
T-Con and panel are used as gate/source drivers. This makes the TV thin and reliable.
Thank you Al Ameen Electronics
