Timer Calculator using 555 IC
555 Timer Calculator version 4.1
download from the attachements
This calculator will provide a number of component values for the delay you want or the frequency.
You can specify “10ms” or “4.5kHz” in the text fields. How often do you want the timer to produce an output? Seconds
What frequency do you want the timer to operate at? Hertz
  • timer_free_setup.zip
