laptop related files and text and photos and post for tips and tricks for repairing
There are several types of bios​
As we have seen so far, the term BIOS in computing derives from the abbreviation of Basic Input/Output System, and we have already learned that it basically consists of a chip that has the function of starting the computer and at the same time, this chip is responsible for coordinating the flow of information that takes place between the different components of the PC and its motherboard and is responsible for coordinating the flow of information that takes place between them.
Now that we have a clear definition of BIOS, we should also know that there are different types of BIOS that are generally differentiated by the method that the BIOS manufacturer uses to record the information on the chip for the type of motherboard on which it is installed. It is also differentiated by the features it offers to the user.
In fact, today there are several types of BIOS, but three of them are the most common and their main characteristics are explained below.
ROM
Its name is an acronym for the English word “Read Only Memory”, and one of its main characteristics is that it can only be recorded by the manufacturer at the time of chip development.
Al tratarse de una memoria no volátil, toda la información que un chip de este tipo de BIOS, en principio, no se ve afectada por la manipulación o modificación. Por lo tanto, aunque se apague un sistema con una BIOS ROM, los datos no se perderán y el funcionamiento normal del disco duro del ordenador no se verá afectado.
Esto, por supuesto, garantiza la disponibilidad de toda la información contenida en la BIOS.
EPROM
El nombre se compone de las primeras letras de las palabras inglesas Erasable Programmable Read-Only Memory (EPROM) y Electrically Erasable Programmable Read-Only Memory (EEPROM).
Es un tipo de BIOS que es reescribible y tiene la capacidad de ser programada a partir de pulsos eléctricos. Por lo tanto, la información contenida en este tipo de BIOS es modificable y extraíble.
Para grabar este tipo de chip BIOS se requiere el uso de luz ultravioleta, por lo que este tipo de chip contiene una especie de pequeña ventana transparente en la parte superior.
FLASH BIOS
Comúnmente conocido como memoria flash, este tipo de BIOS es el más utilizado en los ordenadores actuales, ya que se considera uno de los mejores disponibles en el campo de la tecnología informática hoy en día.
Entre sus principales características está que la memoria flash de la BIOS es un chip volátil, lo que significa que se puede reescribir, en este caso sin necesidad de utilizar un dispositivo especial para borrar la información.
Por esta razón, la BIOS de la memoria flash se puede actualizar de forma fácil y permanente, e incluso los usuarios sin experiencia pueden trabajar con ella. Para ello es necesario un programa que permita la grabación, que se realiza con pulsos eléctricos.
Otro tipo de BIOS: PNP
Los mencionados hasta ahora son los tipos de BIOS más comunes que se utilizan hoy en día, y por supuesto la BIOS Memory Flash más utilizada en los ordenadores actuales.
Sin embargo, debes saber que existen otros tipos de BIOS que pertenecen a la última generación de tecnología, normalmente llamados PNP, acrónimo de la palabra inglesa Plug and Play.
Este tipo de BIOS tiene la capacidad de detectar automáticamente los dispositivos externos conectados al ordenador y también asignar automáticamente los recursos necesarios para que este dispositivo de hardware externo funcione correctamente.
Otras categorías de tipos de bios​
La BIOS (Basic Input/Output System) es un componente fundamental en un ordenador, ya que se encarga de realizar las funciones básicas de arranque y comunicación entre el hardware y el software del sistema operativo. A lo largo de la historia de las computadoras, han existido diferentes tipos de BIOS, aunque hoy en día la mayoría de las computadoras modernas utilizan lo que se conoce como UEFI (Unified Extensible Firmware Interface). Aquí te presento algunos de los tipos de BIOS más relevantes:
  1. BIOS Tradicional:
    • BIOS IBM PC: Este fue uno de los primeros tipos de BIOS utilizados en las computadoras personales IBM PC originales en la década de 1980. Utilizaba una interfaz de texto y estaba basado en ROM (Read-Only Memory) física en la placa base.
    • BIOS AMI (American Megatrends Inc.) y Award: Estos eran dos de los fabricantes más comunes de BIOS tradicionales. Producían BIOS que eran ampliamente utilizados en computadoras de escritorio y portátiles.
    • Interfaz de usuario limitada: Los BIOS tradicionales tenían una interfaz de usuario muy básica basada en texto, lo que significaba que la interacción con ellos se hacía mediante comandos y menús simples.
  2. UEFI (Unified Extensible Firmware Interface):
    • Reemplazo del BIOS tradicional: UEFI reemplaza gradualmente a los BIOS tradicionales en la mayoría de las computadoras modernas. Es un estándar más flexible y versátil que ofrece una interfaz de usuario gráfica, capacidades de red y almacenamiento más avanzadas y mejor seguridad.
    • Interfaz gráfica de usuario (GUI): UEFI proporciona una interfaz gráfica de usuario que permite a los usuarios interactuar con la configuración del sistema de manera más intuitiva, similar a un sistema operativo.
    • Arranque seguro (Secure Boot): UEFI introduce características de seguridad, como Secure Boot, que ayudan a proteger el sistema contra software malicioso durante el proceso de arranque.
  3. Coreboot:
    • Open source software: Coreboot is an open source project that seeks to replace the traditional BIOS with a faster and more customizable implementation. It is used in some computers and specialized devices.
  4. custom and proprietary BIOS:
    • Some brand-specific computers may use custom or proprietary BIOSes that include brand- or hardware-specific features. These BIOSes are often based on UEFI but may have custom modifications.
