What is 555 IC?
The 555 is an 8-pin chip that can be turned into lots of different things (building blocks). The circuit inside the 555 is just an amplifier with 2 inputs and an output.The parts you add to the chip determine the final result (effect). In most cases you add a capacitor and resistor to produce a circuit known as a TIME
DELAY CIRCUIT and the chip has a detection-pin and an amplifier (also called a power amplifier) to produce an output.
It is not just a "timer," "delay" or "oscillator" but is capable of being converted into these and
maybe 100 other circuits. Just call it the "555"
![1737099260121.png 1737099260121.png](https://laptechinfo.com/data/attachments/3/3544-ca9a50207b6077f6ee1c49f01c964ba3.jpg)
The 555 HOW IT WORKS
To understand how the 555 works, you need to know how to connect pins 2 and 6.What you should know is as follows:
Pins 2 and 6 should never be left disconnected because doing so will cause the 555's output to occasionally be LOW or HIGHDue to their HIGH IMPEDANCE, pins 2 and 6 have the ability to detect static electricity and occasionally turn the 555 on or off.
Here are the 4 possibilities for pins 2 and 6:
The four options for pins 2 and 6 are as follows in the Table below:
Pin 2 LOW | Pin 6 LOW | Pin 3 HIGH | Pin 2 controls the 555 IC. Pin 6 Has no effect |
Pin 2 LOW | Pin 6 HIGH | Pin 3 HIGH | Pin 2 controls the 555. Pin 6 has NO effect. |
Pin 2 HIGH | Pin 6 LOW | Pin 3 LOW | Pin 2 controls the 555.(the 555 does not turn on) |
Pin 2 HIGH | Pin 6 High | Pin 3 LOW | Pin 2 controls the 555. (the 555 does not turn on) |
Connect pin 2 and 6 together. Take both HIGH . . . .. Pin 3 LOW (toggle Mode)
Connect pin 2 and 6 together. Take both LOW . . . .. Pin 3 HIGH (toggle Mode
Toggle Mode is also called INVERTER MODE . . . The output is opposite to the input. The 555 takes 10mA ALL THE TIME . . . even when the output is LOW
