| S.No | Code | Abbreviation |
| 1 | AC | Alternative Current |
| 2 | ACDRV | Adapter current drive |
| 3 | ACGOOD | Valid adapter active -low detect logic open drain output |
| 4 | ACIN | Adapter current input |
| 5 | ACN | Adapter current negative ( taken from current sensing resistor ) |
| 6 | ACP | Adapter current positive ( taken from current sensing resistor ) |
| 7 | ACOP | Adapter current over current protection |
| 8 | ACOV | Adapter current over voltage protection |
| 9 | ADP+ | Adapter positive supply |
| 10 | ADP_ID | Adapter Identity |
| 11 | AGND | Analog Ground |
| 12 | ALWP | Always on Power |
| 13 | B+ | Adapter or Battery power rail to power the circuit ( this is the point motherboard takes power to all the other areas of the motherboards power requirement) |
| 14 | BATT | Battery |
| 15 | BAT+ | Battery power rail to power circuit |
| 16 | BAT_DRV | Battery MOSFET's gate driver |
| 17 | BAT_V | Battery voltage |
| 18 | BOM | Bill of material management |
| 19 | BT | Button |
| 20 | BT_EN | Bloototh Enable |
| 21 | BUZER | It means connected |
| 22 | BYP | Bypass |
| 23 | CHGEN | Charge enable active-low logic input |
| 24 | CIN | Input Capacitor |
| 25 | CLK_EN | Clock Enable |
| 26 | CN | Connector |
| 27 | CRT | Cathode Ray Tube |
| 28 | CSIN | Current Sensor Input Negative |
| 29 | CSIP | Current sensor input positive |
| 30 | DC | Direct Current |
| 31 | DM | DIM Socket / Socket Memory / DDR Socket |
| 32 | DOCK | Docking Socket |
| 33 | EC | Embedded Controller |
| 34 | EC_ON | Embedded Controller Enable / IO Enable / SIO enable |
| 35 | EMI | Electromagnetic Interference |
| 36 | EN | Enable |
| 37 | ENTRIP | Enable Terminal |
| 38 | F | Fuse |
| 39 | FSEL | Frequency Select input |
| 40 | GATE | Trigger Mosfet Gate |
| 41 | GND | Ground |
| 42 | GP | Ground Pin |
| 43 | GPI | General Power Input |
| 44 | GPIO | General power input and output |
| 45 | HDMI | High definition multimedia interface |
| 46 | ID | Continuous Drain Current |
| 47 | IDM | Pulsed Drain Current |
| 48 | IIN | Operating supply current |
| 49 | IIN (SHDN) | Shutdown supply current |
| 50 | IIN (STBY) | Standby Supply Current |
| 51 | IS | Continuous source current |
| 52 | IVIN | Battery Supply Current at VIN pin |
| 53 | JP | Jumper Point ( there are few jumper points will be there on the motherboard for troubleshooting and separating circuits, this jumper point help us to troubleshoot easily ) |
| 54 | KBC | Keyboard Controller / IO / SIO / EC - all are same |
