Windows How to get insert special characters in Microsoft Word Document
Windows related posts, like diskpart, pendrive, updates, tricks and etc..
Microsoft Word, like all text-based programs, assigns a numeric character code called ASCII (American Standard Code for Information Interchange) to each alphabetic, numeric, and special character on your keyboard. This code allows us to open text files in nearly any software application and explains why some program passwords are case-sensitive (for example, capital ‘A’ is ASCII code 65 and lowercase ‘a’ is ASCII code 97). You can insert any or all of these codes/characters (individually) with one simple keystroke: Alt + the decimal code on the numeric keypad (notice that the digits across the top of your keyboard do not function), or you may use the Symbols Library.
Insert symbols from the Symbols Library.​
The Symbols Library is the most popular and well-known mechanism for putting non-keyboard characters into a Microsoft word document is very simple:
  1. Click the Insert Tab in word Document
  2. Click Symbol
  3. Click More Symbols
  4. By Default, normal text will be selected.
  5. Select the symbol that you want and click insert button to insert to word document1724325713378.png
Alt Key Combination Symbols Details​
Numerous websites that plot the ASCII and symbol tables may be found on the Internet. I’ve been to two: Special Characters — Alt Code Sequences and ascii-code.com. Don’t forget to hold down the Alt key while entering a 0 (zero) before each code. For instance, if the copyright sign on the chart is 169, you need to type 0169 (that is, from 0 through 255).
